Letus35 Original VS. Letus35 enhanced
DownSouthAlec
I was looking into purchasing an original but is the enhanced really worth the more money. I'm not going to be using any other lenses except just the letus because i don't know much about 35mm adaptors. Footage would be great. Thanks!
Maybe I'm misunderstanding you, but... you are going to have to have at least one lens, a 35 adapter by itself is useless... It's an adapter. Meaning it allows you to use 35mm lenses with your camera.
Flip enhanced would probably be the way to go over the original letus if you are looking for something on the cheap. For one thing, as mentioned above, it flips the image upright for you. I would imagine the picture quality is quite improved over the original Letus as well.
Later,
Jason
How much are the interchangable lenses?
The sky is the limit as all manner of SLR and even cinema lenses can be used given the right mount. Although I believe the Flip Enhanced is limited to Canon FD or Nikon. But even there you can expect to spend anywhere from $200 to $2000 for a set of lenses.
