Is it ok to leave battery and P2 card attached to the camera all the time?
mb72378
I have a pelican 1610 case and I leave my camera in it with the battery attached and the P2 card inside the camera. Is this ok? I just saw a post about an exploding battery and read something about how sometimes they leak. (Both of the batteries I have are Panasonic) I just wanted to make sure I wasn't doing anything that would put my camera at stake.
Remove the battery during transit because the tabs on the camera have a tendency to break.
There is always a small draw on the battery when it's attached which will decrease it's useful life over time. Lithium batteries can only go through a limited number of charge/discharge cycles before they're dead.
I've never taken my battery off a camera in 5 years.. never had a issue... *knock on wood*
Using 3 batteries right now.. I always carry my camera in transit.. battery attached...
Cheers
Cheers
You're playing with fire. I did that too... until one of my tabs broke off. Now I play it safe.
Cheers
Just because you have done it without a problem doesn't mean one SHOULD. The HVX has a weak spot, and the weak spot is the battery tabs. I know this from personal experiences and from reading from many others on here.
Thank you everyone for all of the replies. I have "foamed" out another spot next to my other battery in my pelican for travelling.
