OK, this will be unusual post from me, as you have seen we never defend our products, just let the users judge. But I have to jump in to comment on this.
Barry, you don't need to test further, there is no need, as I know exactly what happened. And you would find out exactly the same result if you do the same test on the same GG.
This is the very reason we had to recall about the first20 Extremes when it entered the production version. We mistakenly assembled the test ground glass (the see through ground glass) to the Extremes. With that ground glass, you would see the same phenomenon. I hope Dennis didn't ship a lot of these GG already.
Here is the way you can prove it, if you have time, of course:
1. Take a piece of glass about 1-2mm thick
2. cut it to the size of the GG holder
3. use the sand to hand sand it, just a little, and let all the aerial images to pass through
4. Put it on your adapter (replace the current GG of course)
5. Do the same test like in the video, you'll see it perform "better" than the demonstration in the video.
The problem? You just let the whole aerial images to pass through the GG and this is the worse thing that a 35mm adapter can do.
OK you have just tested the one extreme of the GG.
Now do the test again, but this time, sand the GG really well (or get the piece of GG from Flip Enhanced or SG Pro or Extreme, they are about the same see through level, which is almost none). Do the same test again. Uh oh, I cannot get that "cool feature". But this is what you want for a 35mm adapter.
I hope this will put to rest this phenomenon as it is a known thing. All DIY adapter builders out there should experience the same thing.
Please do not email me regarding this until you do the steps above. Have fun disproving me
