You can really see the lean in the res charts on those pans.
where do you see a lean? If I look at the static shot and compare it to the panning shots i can't see any lean difference.
I think what maybe was seen is when the peaking feature is turned on, when you pan looking at the viewfinder, the peaking disappears and then reappears when you stop the pan. I think this is just the slow peaking response from motion blurs causing the peaking to disappear and reappear. When looking at it in post I do not see it.
I see it flipping back and forth between the shots, very clearly -
After looking at them in 'preview' on the Mac, I took them into photoshop,
layred them on top of eachother, lined up the top edge to make sure they're aligned.
Then you can just turn the one layer on and off and the lean is pretty evident.
I think it's well established that when you pan on an ex1, things lean.
Gentlemen,
Who cares?
Barry,
Will you at least concede from my 1/60 charts that the resolution loss is not "a couple hundred lines of res?"
People who will be doing match-moving and compositing. Anyone using SynthEyes, for example, which is why its maker went on a rant about rolling shutter cameras. Skewing and wobbling make those type of processes extraordinarily complex, if not impossible.Gentlemen,
Who cares?
I'll look at 'em. My recollection from the tests we were doing is that it was clearly resolving 800 vertical lines of horizontal resolution, and during panning it dropped to as low as 600. Can you point me to a link to your charts?Will you at least concede from my 1/60 charts that the resolution loss is not "a couple hundred lines of res?"
