Gundorf Dunderklumpen
So then removing the pulldown from the 1080 footage during ingestion will give the exact same "progressive" cadence "look" as 720p?
Yep. Only sharper and with less compression.So then removing the pulldown from the 1080 footage during ingestion will give the exact same "progressive" cadence "look" as 720p?
There are good reasons to shoot 720 -- taking advantage of 720pN mode and space savings on the card, and definitely variable frame rates.
But if neither is an issue, then yeah, 1080 is the obvious choice.
Exactly. The HVX and HPX do shoot 1080p. Why is it called 1080i 24/25p? Because its embedded on the I stream. It fills the I cadence with progressive full frame pictures, basically fooling the 50i/60i to believe its transporting a full 50i/60i stream, but in fact is transporting a full 25p/24p stream.
And for sports. with 60p, you get solid images on fast movement, which is a problem in interlaced recording
And yet the HPX3000 offers "true 1080p" recording described more or less as a breakthrough. How does the HPX3000 1080p differ from from the HVX and HPX500 1080p?
I guess what's confusing me is this statement from the company: "Panasonic is excited to announce the AJHPX3000, the industry’s first native 1080p one-piece camcorder for master-quality high definition video acquisition."
