What kinds of case for the EX1 is recommended?
myCharlie
I like to buy a hard case (air tight, water tight) case for my Sony EX1 camera. What are some of the recommendations? I was looking at the Pelican cases here. However, I have never used a Pelican case before and not sure which which one will fit.
Any help is appreciated.
You'll need a 1550 or larger due to the ex1 being wide. It gives you plenty of room for other stuff too.
Thanks so much for the input. I was wondering if I should wait for the case that is specifically made for the EX1 or buy a Pelican case. It seems to me that a Pelican case is very sturdy and tough.
Pelicans are the best hard case - a bit heavy but very sturdy and truly waterproof.
The pick and pluck foam is not so hot - it shreds after awhile. Best to get a Peli and get custom foam made for the inside. There are many companies that do that.
It's only a matter of time before someone makes a precut foam set for the EX1, just as several companies do for the HVX.
If I were you Id get a pelican 1650, with plenty of space and trolley plus a small over the shoulder bag suitable for carry on luggage and thats very flexible for other purposes, walking long distances etc. Pelican alone can be cumbersome and overkill at times.
Many thanks for the suggestions. Mathew77, will you give me some of the links to those companies that make custom foam? It would be nice if any can make a precut foam set for th EX1 so that I don't have to manually do it myself.
Try Googling "pelican case custom foam"
Lots of choices.
Never tried any of them, so I cannot recommend. In the past I've gone to my local Anvil case guy and had him make the foam.
EX1 Hard Case
EX1 Hard Case
Abel Cine Tech will have a Storm 2720 case with a custom EX1 foam available in a few weeks.
Yes thats the case we will be using. The custom foam insert is at the shop being made so we should have it back next week to approve then we can start assembling the cases. The price will be around $300.
Okay, do you ask for a custome pre-cut foam specific for the EX1 or that they will start selling an already made pre-cut foam plus case in a few weeks?
I've been searching for a pre-cut foam specific for an EX1 camera and I couldn't find any. Will someone post some site or place where they are able to do a pre-cut foam specific for EX1?
Okay, I'm torn between these two cases:
Pelican 1560 and Hardigg Storm Case - iM2720
Pelican case is $200, I assumed that include foam but I'm not sure what the price on the Storm case. I've read some reviews on another forum and it seemed that both brand are very good. What I like more about the Storm case is that it's 3.2 pounds lighter than the Pelican. Storm case has multi layer foam...not sure about Pelican. It would be nice if there is a EX1 camera pre-cut foam available. So what else should I be considering?
