Okay, the scariest thing I just read about, is if you're recording audio on a seperate recording device, you must make sure that recording device is set to record audio at the same rate/speed as your camera. I'm shooting on an HV20 at 24p. What settings should I enter?
This brings me to my next question, which likely stems from your resulting question -- "What are you recording on?" The answer is... I don't know.
I'm not even sure how all this audio stuff works. You send your mic into your mixer, right? And adjust the levels there. Then you have your mixer connected to your audio recorder (which in this case will be something digital, right?) And you record your audio onto that "hard drive" recorder. And that's how you get your audio. Well, I'll probably be using one of the cheaper mixers and audio recorders then (any suggestions welcome) and hopefully that will be enough information to answer my first question - what settings should I enter in order to record at the same rate as my HV20 at 24p?
Oh, and if I change it to 60i, I would then have to change my audio settings as well?
