starcentral
Theoretically not having to zoom as far onto the screen would mean less grain pattern would it not?
I think the problem is that the flip unit isn't out yet, and I believe the unit he has been testing with doesn't have the spec optics yet which are on the way now, so the zoom level is different with the test version than what the final number would be. Hence no ability to give you an answer yet as the final retail version isn't yet available.
Later,
Jason
The HV20 is amazing with our flip...but if you use it on another adapter requiring a high degree of zoom-in, you'll get serious edge falloff from the HV20 lens itself! In other words, correct alignment and less optical zoom in both improve image performance with the little cam. I was so impressed with HV20 (and predicted high demand for a solution) that we even manufacture a one-piece 43-72 step up ring for it.
The Brevis is the only adapter that has a specific setup for the HV20 and the other small HD cams...they do need one for full frame performance at all focal lengths.
Wow. I am really on the fence between these two adapters. I need to purchase in the next two weeks. I really cant decide. I like that the Letus is an 'all in one' package, but I am still looking at the Brevis. It is so hard to make a purchase like this without using one.
It appears anecdotally that whatever people buy, they like.
I just don't know. Maybe I will flip a coin....
The Letus Extreme works on smaller cameras as well.
