Ikegami TM9-1 9-Inch Broadcast Color Video Monitor
zigernot
This is a perfect condition Ikegami tm9-1 monitor. Minimal wear on the case, colors are perfect.
The Ikegami TM9-1 is a broadcast quality 9-inch color video monitor designed to be used in the field or in the studio. It can be used as a confidence screen at a camera position or it can be part of the switcher package at a director's location. This unit has Composite and S-Video inputs each with a looping output. There is BNC connectors for video Sync and an 8-pin connector for Tally lights. This monitor is built into an all metal cabinet for maximum durability.
World Wide Video Watching
The TM9-1 is a multi-format monitor capable of accepting Composite Video or Y/C signals from NTSC or PAL sources. There is a front panel button to switch between video systems.
AC/DC Power Options
The monitor can accept virtually any power source from 100 volts to 230 volts 50/60 Hz from any AC outlet. A convenient 4-pin XLR connector is provided for DC power input. In addition threaded mounting holes are provided for Anton Bauer or PAG battery brackets.
Display Capabilities
The TM9-1 is a professional video monitor capable of displaying images in their correct natural colors. There are several functions that allow the operator to dial in the baseline picture-looks including buttons specifically for Blue Gun, Phase, Brightness, Contrast and Pulse-Cross.
I would like $350 for this monitor.
