Hey everyone. I don't post often here or own a DVX but im a big DIY supporter and a fan of this board.
I have had a wooden pvc pipe dolly for a while but im looking for something more versatile, sturdy, professional, and upgradeable.
I decided to go with steel because of its strength and availability. So far this dolly has cost about ~$100 with wheels included. All of the materials were purchased at Home Depot, and other hardware stores. I don't have steering parts available to me so thats something im leaving for later.
Here is the 3d design I came up with before I started buying materials. (pseudo scale accurate)
Here is what it looks like once built:
What I should have done different / will improve:
(1) The two tubes at the bottom will enhance the structure and also provide mounts for accessories.
(2) The tube supports seen from above placed at the intersections of the beams will support seats, accessories, ect...
(3) Side bars will be doubled up to help keep the dolly shape solid and add extra reinforcement.
I estimate the completion of stage 2 to cost ~$45 more in materials.
I have been thinking about buying 4 more smaller wheels and cutting the tires off. Im going to try and ride the "rims" on PVC and see how well that works. If it works, then I may:
A side note. The reason I decided to use nuts/bolts in the construction instead of welding is because this way I can break this thing apart into 7 steel tubes and 4 wheels that will easily fit into any car. Its lightweight, simple, and incredibly easy to transport.
Oh the surface... Im reluctantly considering wood... I don't like the idea of wood because
* its heavy
* big
* difficult to transport
* does not like moisture
But on the other hand, its
* cheap
* easy to work with
* can be cut to smaller sections
* can be drilled into to expand / mount accessories
I have not ruled out a metal surface... Im going to think about it....
If anybody had any ideas on enhancing this design I would be happy to hear your thoughts.
Other then that...
Thanks for looking and happy building
- "axle" is too long. ~170 pounds on a corner will stress it and flex the axle 1-2mm. I want this dolly to support at least two people. And if I can cut an inch or so off to improve the build, im all for it.
- Can't steer it. I found a steering kit for ~$70... I'll get it once I complete stage 2 of the build.
- The wheels are fine but I was hoping for something more flat when inflated. Its curved. Ride is smooth but not as smooth as I would hope. I found some wheels for $150 but im not ready to spend that just yet.
- Extending the surface area with additional platforms.
- Camera mounts
- Equipment Mounts
- A) Keep them on the side. When I need rails just switch the wheels.
- B) Mount both the wheels and rails together so all I have to do is place the dolly on track.
* its heavy
* big
* cheap
* easy to work with
Other then that...
