Deuceofspades
Can you calibrate that puppy? (blue mode)
final word on this monitor being a good decent starter kit to use with hvx?
https://www.ggvideo.com/tot_lcd703hd.php
Are there others that are equal or this a good pick for the package/price/quality.?
Without focus assist, focusing wide angle shots below 40mm becomes a huge challenge. At 24mm, the Marshall is almost useless unless there is significant separation between your subject and background, there just aren't enough pixels in the display. If you're going to shoot outside a lot, you absolutely will need a good hood, as all these monitors are pathetic in bright conditions.
Unless you're not very picky about how sharp your footage is, you will eventually realize that HD 35mm adapter shooting requires a monitor like Bruce Allens with lots of pixels, or focus assist like the Panasonic and Nebtek.
Personally, the NEB70HD with the trans-reflective display is the only way to go.
Just a quick note on my BT-LH80W 7.9" monitor. Last month when filming my 1st AC got distracted and pulled the camera off the steadicam while it was connected to the BT-LH80W via component cable. The Monitor flew 12 feet through the air and dropped flat on it's lCD on to asphalt. I picked it up, blew the dust off it and kept shooting. No problems with it to this day. Just cosmetic. It was worth paying a few extra bucks to get a rugged monitor. If it was an IKAN monitor, I might have been out $900.
Emre Tufekci www.productionpit.com
