FS: THE HVX DEAL (with 16GB P2 Card and M2 and extras)$5400
Hunter Hampton
Carbonite Member
Howdy folks.
Well I just Picked up the HPX500 and now its time to make some money back on my HVX200 package.
Here are the Photos: http://flickr.com/photos/8625918@N04/?saved=1
Includes:
1 HVX200 camera with low hours
1 16GB p2 card
1 RedRock Micro M2 (properly set up with custom light weight rod support)
1 Nikon Mount
1 Cinevate HD achromat ( I liked it better than the Redrock Brand)
1 82mm step ring for hard mount
1 CineBags Back pack that fits everything (very comfy)
2 Longlife Batteries (about 4-6 hours each)
1 Battery charger
and all of the cables that come with the camera
Notes:
The only flaw you will find on this camera is the small crack on the side of the lcd screen (see picture), it is only cosmetic and does not affect the LCD in anyway.
The HD M2 kit has been custom set-up for this camera and it is a hardmount. The back focus has been properly set up and there is edge to edge sharpness with no vinnetting on every lens I have tried from a 15mm to a 200mm ( for example I put a sigma 15mm f3.5 and it had zero dark corners.)
Also the Rod support I custom made from cavision parts, it allows you to put the M2 on and off in seconds and is rock solid and extremely light, it includes short 15mm rods, and it allows you to use the HVX in shoulder mount style when you have a reference monitor (like an lcd), there is a plate on the bottom for your tripod plate. If you want longer rods, You can use any brand of 15mm sized rods.
________________________________________________________________
$5400 takes it all (plus shipping from Portland, Oregon 97056)
Coincidentally I did some tests with Hunter the other day, a real stand up guy who takes care of his stuff, highly recommended. If I didn't own a Red I'd be strongly tempted to do this. Someone snatch this up!
