EDIUS 4.52 update now available
If you weren't aware already. I'm a little behind in noticing myself :)
Go to www.canopus.com
Login and go to product related downloads. You will find it there under EDIUS broadcast v4.
It's another huge download at 469 megs....
Fixed in this version (from v4.51c)
  • Fixed an issue where EDIUS crashes upon opening a project file, after opening another project file previously.
  • Fixed an issue where copy operations would fail from within the P2 Select application.
  • Fixed an issue where EDIUS crashes when deleting the search results folder of an imported sequence.
  • Fixed an issue where EDIUS crashes when exporting a project to AAF, which features locked tracks.
  • Fixed an issue where a folder is generated with the same name as the project name in the project folder, when opening a new project.
  • Fixed an issue where EDIUS crashes when selecting a folder registered in the BIN window which features a TitleMotion clip.
  • Fixed an issue where an error occurs importing a PSD file into QuickTitler.
  • Fixed an issue where in VTR Emulation mode, EDIUS could cue up back to the previous day.
  • Fixed an issue where SWF clips were not displayed, after applying the v4.5 updater.
  • Fixed an issue where the time margin was incorrect when capturing around 24H in batch capture.
  • Fixed an issue where the clip information window was reporting incorrect info after changing a nested sequence clip’s speed on timeline.
  • Fixed an issue where EDIUS crashes after attempting to capture to a set of IN/OUT points that were outside the limit of a correct 4-point capture.
  • Fixed an issue where the A flag for "Progressive frame" was not flagged correctly within Canon 25p output stream, from the HDV exporter.
  • Fixed an issue where EDIUS crashes when importing MPEG-2 TS files that were converted by FireCoder.
  • Fixed an issue when capturing video with long durations.
  • Fixed an issue with the importing of Imaginate (IVP) files.
  • Fixed an issue when importing certain title clips.
  • Restored live output of TitleMotion/Quick Titler title composition with EDIUS hardware (related to other issues now resolved in v4.52).
Known Issues:
Here is the current list of known issues that QA have identified with the latest build of EDIUS 4.5 (4.51c). These will be addressed in future updates.
Note: These issues may not affect all users, but instead affect certain installations.
  • EDIUS crashes when using multiple nested sequence.
  • EDIUS crashes when making many camera points in multicam mode.
  • EDIUS hang up when canceling exporting ProCoder3.
  • "Disabling tracks" is not effected.
  • A file is divided when capturing MPEG2 TS video over 24H.
  • Improper embedded packet of HDV stream that is encoded by SpeedEncoder.
  • EDIUS crashes when closing after minimize/maximize EDIUS window changing user account.
  • EDIUS crashes when importing MPEG4 files which are converted by FireCoder.
  • Audio noise occurs when playing back clips exported directly to XDCAM.
  • AAF exported from PDZ-1 is not supported.
  • EDIUS process is existing when closing EDIUS after playing back Infinity (MXF) files.
  • Exported HDV stream doesn't have "Binary group".
  • Field marker is not available with 50p/CtsTimeCode.
  • JVC BR-HD50 is not detected from MPEG TS Writer.
Later,
Jason
Need urgent help!
Need urgent help!
Hi
Just downloaded & installed 4.52 ok, but then:
I can't open anymore my 4.51C projects!!
Then trying, EDIUS crashes without any message. A new projects seems to work so far. Importin a sequence does the same.
Is the new version really 100 % uncampatible with older projects? My seller (importing company) did'nt warn from this...
Any fix, or should I install it all over up till 4,51.
jussi
You shouldn't be having problems with prior projects.
Have you tried uninstalling v4.52, then installing v4.x and updating again?
4.52 problem
4.52 problem
Yes have uninstalled 4.52 twice, started from 4.0 which runs ok, it opens also the 4.52 project. Uppgraded then straight to 4.52 but same result - crashes with the first try. Next I try to uppgrade only to 4.51c which was working ok.
jussi
jussi,
in your old project, did you have titles created by title motion,
or by the quicktitler?
does it contain bitmap files, like tga, bmp etc.?
try to delete the rendered files and just leave the raw footages before opening them.
Ted
I used title motion only, but not any special bitmaps etc. just basic things. I did uppgrade to 4.51c and it's running ok. ;y seller keeps saying that AMD might be th esource of problem. I have a year old dualcore with 4 gb mem. All other programs run steady though - Corel, Liquid and Adobe CS3 (tryout) but also Elements 3.
jussi
EDIUS is optimized for Intel in some places and AMD in others, so the overall wash should be good optimization on either platform.
If all the same components are available (QuickTime, TitleMotion Pro, VST filters, etc) then it should load OK.
You aren't using any VST filters in your project are you? They can be problematic.
