When can I order it? Also will it record audio, unlike the Andromeda?Actually it does, it just hasn't been released yet. Some people said the Red One was vapor ware....
If the Hydra would [supposedly] provide 86 dB of dynamic range, does this mean that a HVX\Hydra system would rival film in terms of latitude?
In theory, any 12 bit ADC hooked up to an analog sensor should be able to provide a full 12 stops. The Red One uses a 12 bit setup, but in reality, they can only pull in around 11-11.5 depending on who you ask.
How many shades of gray you can capture depends largely on two major things:
1.)Bit depth/sampling/compression (ok, so maybe thats a few things LOL)
2.) Sensor quality.
Its clearly feasible to create ADC's that run at very high bit depths, the Dalsa Origin uses 16 bit!
The big hang up though is the sensor itself. If a sensor can't PHYSICALLY output 16 stops worth of latitude, then guess what... 16 bit sampling coupled with either uncompressed 4:4:4 sampling (for CCD cameras) or RAW (for bayer filtered CMOS cameras), isn't going to give you 16 stops. If its physical max is only 5 stops, then thats all you'll ever get, the rest of what you gain is purely sensor noise.
Make sense?
Another variable that seems seldom discussed is white balance in three chip cameras. White balance settings and filtration can alter how much usable range you capture, especially in the highlights. The Viper Filmstream takes this into account, and its also the reason why the video comes out looking green.
Another variable, at the sensor level, is the actual size of the sensors photosites. If I'm not mistaken, the DVX and HVX use the same size sensors, but the HVX has smaller photosites. The issue with smaller photosites has to with their ability to capture light. Smaller means lower performance, assuming nothing has been changed, like using better materials to make the sensor. Smaller photosite sensors usually have a higher noise floor (meaning noise is more evident), and they tend to have less latitude, due to their difficulty in picking up light. One of the major reasons why larger broadcast cameras perform better than Mini DV cameras has a lot to do with the sensors photosite size, the other is better signal processing, and this is very evident with the Andromeda. Its sensors put it at a disadvantage compared to larger cameras, but because the user has raw sensor data without any compromises, its capable of beating the larger cameras performance on so many levels, despite using an "ok" level lens. You reach a point where great lenses and bigger chips simply don't add up when you put the resulting signal thru processing hell.....
For those who are wondering, I'm currently pulling a full 9.5 stops out of the Andromeda, and I'm recording to 10 bit via a 12 to 10 bit LUT. Why I can't get a full 10 could have something to do with the LUT and its output precision, or, I could be hitting the sensors physical limit. I can't be sure until the 12 bit linear firmware upgrade is released. Even if I don't extend my range, I can be sure that I will have even better color to work with, which is always a plus in my book.
Since I haven't worked with Hydra, I can only speculate on how good the specs will be, but even if the camera has less latitude than the Andromeda, it will still be a huge leap up from what a stock HVX could ever offer, that much I'm sure of.
Hope that helps!
just it needs to run on pc......
for audio on the HVX couldn't you roll the P2 card and record audio and hit record on the PC/Mac to start the andro and then sync later? Or does andro interrupt the P2 deck?
