disjecta
Lucky Duck
Given that there has been a lot of info getting kicked around in multiple posts about the Extreme, I thought I would consolidate all relevant information in one post. Sorry if I left anything significant out.
The Letus35 Extreme flips the picture right way up. This feature is built into the design already.
Improvements being made to the full production version of the Extreme are:
FOOTAGE -
Disjecta:
OUTDOORS:
The first one was taken at my son's baseball game with a mixture of dull and sunny skies at sunset. Nice for showing sharpness and color as well as bokeh. Lenses used are identified in the footage.
http://www.dvxuser.ramjetfilms.com/extreme_cc_720.wmv
INDOORS:
This second one is a test I did with one 250w spot to demonstrate the lowlight capabilities of the Extreme. Nikon 50mm f1.8 and Nikon 100mm f2.8 used here.
http://www.pinelakefilms.com/XHA1/extreme_interior_2.wmv
INDOORS:
Third one is also demonstrating the lowlight capabilities of the Extreme. This was shot under 4 x 50w spots over the stove in my kitchen. The lights are just simple practical stove lights, nothing special. Again, for 200w of light, this is quite amazing footage coming from a 35mm adapter. I used a Nikon 50mm f1.8 lens for this.
http://www.pinelakefilms.com/XHA1/extreme_interior_720.wmv
INDOORS:
Natural lighting shots and 250w keylight shots (with subtle backlight and fill)...all indoors
50mm f1.8 zoomed to 35mm Academy size. The Nikon was open to f1.8, Canon lens was set to f3.4 for the 250w test...can't remember details of natural light shots.
http://www.pinelakefilms.com/XHA1/extremetara.wmv
ZOOM LENS TEST:
I used a cheap Tamron lens (with Canon EOS/EF fitting, the only zoom I had available). It's a 28-80mm f3.5-5.6 and has some serious softness on the edges...it is also soft around the edges when using it with a still camera so don't judge sharpness. The weather was dull and wet and I was shooting out an office window with lots of reflection. It couldn't be much worse. I am posting this because I want to demonstrate that there is no vignetting when using a zoom lens.
http://www.pinelakefilms.com/XHA1/zoom.wmv
Ryan Walters’ shutter/slowmo tests:
Sample Video- Interior- Letus Extreme & HVX- (7MB)
http://www.235studios.com/REW-LEFootage-Glass-Chess.mov
Sample Test Video (Shutter speeds & over cranking)- Exterior- Letus Extreme & HVX- (7MB)
http://www.235studios.com/REW-LETest-ShutterSlowMo.mov
The Latest Full res Test stills: (43MB)
http://www.235studios.com/Test02.zip
The original full res test stills: (31MB)
http://www.235studios.com/REW-Logo-LETest.zip
Brett from Resonance Productions: http://www.letusdirect.com/LetusExt.zip
REVIEWS –
Ryan Walters: http://ryanewalters.235studios.com/...533-0C18A26D3F34_files/LetusExtremeReview.pdf
Disjecta initial impressions: http://www.dvxuser.com/V6/showthread.php?t=110557
- Hex key for adjustment/installation (Changed so that it will use 1 hex key for all the screws)
- End caps
- Solid form fitting packaging (no peanuts)
- Logo (will be where the switch is right now)
- Light switch brought to the back to avoid distraction to the audience and easy to be seen by the shooter
- 3 screws to the mounts
- Threaded holes on the bottom of the front of the tube to be ready for support system
- Choice of 72mm or 82mm ring
- A custom bracket will be available for the Letus Extreme that will work with any standard rails support system
- Warranty for the Extreme has been extended to 1 year
- Letus is offering a 100% credit on any Flip purchased within 30 days previous to the launch of the Extreme for anyone wanting to upgrade. Purchases 30-60 days previous will receive a $500 credit toward the Extreme.
- Current ship time in approximately 3 weeks
FOOTAGE -
Disjecta:
OUTDOORS:
INDOORS:
INDOORS:
INDOORS:
ZOOM LENS TEST:
REVIEWS –
