Spotlight Media
I will appreciate any guidance on this issue.
I currently own an XH A1 camera along with a FireStore FS-C direct to hard drive unit. While shooting in 1080i 60i I have noticed that during moving shots, whether I pan the camera myself, or the camera is following someone running, or a vehicle moving, anything moving relatively fast I seem to get what I think are interlace artifacts.
Perhaps I am using the wrong term, but it seems like the image is a little blurry until the camera or action comes to a stop and then you have a sharp image. So I assume it has to do with interlacing.
So my question is, if this is correct, does this have to do with the HDV codec, the camera itself, my shooting abilities? If it is the camera and/or the codec will buying the HVX200 and shooting with that clear up this, sometimes, mess?
I have no problem buying an HVX200 if that will help.
I have a link to some footage that shows the problem slightly happening and I can post a shot that is even worse. The current shot is at www.screwballfilms.com and then right click and download interlace movie, it is a quicktime straight out of the camera.
Thank you so much for what will most likely amount into a pretty novice question based on the knowledge I see on this site.
Cheers
Cheers
