Bayne
This is a Dell 20.1 inch 2005FPW Monitor. No dead pixels, has 4 inputs: DVI, D-Sub, Composite (RCA, the yellow one) and S-Video. All inputs are switchable from the front panel. Including Picture in Picture and side by side picture. Max resolution is 1680x1050.
Price: 200 bucks
Rest of the specs:
Viewable Size: 20.1"
Depth: 9"
Features: Automatic Setup Adjustment, Kensington Lock Slot, 100 mm VESA Mounting, Height Adjustable Stand Included
Height: Compressed: 15.3", Extended: 22.4"
Weight: 17.64 lbs
Width: 18.6"
Image Max H-View Angle: ±88°
Image Max V-View Angle: ±88°
Color Support: 16.7 Million
Display Type: Flat Panel Recertified Monitor / Active Matrix TFT - Desktop
Compliant Standards: 100 mm VESA®, TCO '99; UL 60950, NOM , CE Mark–EN60950, IEC 60950 CCC , TUVGS , NEMKO, GOST, PSB, TUV–S, SASO; FCC Part 15 Class B, CE Mark–EN55022:1998, EN55024:1998, EN61000-3-2:2000, EN61000-3-3:1995 A1(2001), VCCI Class B ITE, MIC, BSMI, ICES–003, C–Tick; ENERGY STAR®, TUV Ergo
Connectivity Technology: Cable
Device Type: Flat Panel LCD Monitor with Height Adjustable Stand
Dimensions (WxDxH) / Weight: 18.6" x 9" x 15.3" to 22.4" / 17.64 lbs
Enclosure Color: Midnight Gray
Image Aspect Ratio: 16:10
Image Brightness: 300 cd/m²
Image Contrast Ratio: 600:1
Max Resolution: 1680x1050 Pixels
Max Sync Rate (V x H): 75 Hz x 83 kHz
Port(s) Total ( Free ) / Connector Type: VGA / DVI-D / S-video / Composite / 4 x USB 2.0
Power Consumption Operational: 75 W (maximum), 55 W (typical)
Diagonal Size / Viewable Size: 20 / 20.1"
Compatibility: PC
EDIT: Reason for selling: I need to buy two like monitors for my editing suite at home and you cant buy this one new anywhere.
Located in San Diego
Price: 200 bucks
Rest of the specs:
Depth: 9"
Weight: 17.64 lbs
Width: 18.6"
Compatibility: PC
