System Error - P2 Micon Error
Thanks again, Barry, for the help - both here and at dvinfo. I sent my card to Panasonic, hopefully they'll find something soon.
I have a shoot tomorrow - 7 interviews - I'm really hoping that I don't have any other "issues" with the camera. I hate the fact that I'm second guessing with it now. I'm actually bringing my beta along just in case because I don't want to lose this client . . . I didn't think I'd have to worry about something going wrong with a new camera. Oh well, I'm sure it's just a bad card but I'll always wonder. Wish me luck!
John
i'm having a "SYSTEM ERROR P2 MICON ERROR" aswell.
the camera is not recognizing the P2 Card on the SD Card when it is put into the camera. any ideas?
I've seen the Micon error when I was fooling around with the frame rate hack (specifically when trying to record 25fps from an NTSC HVX). So I figured that it was my own fault and I didn't even worry about it.
hey barry,
how did you fix that?
i have one 16 gb P2 Card that the camera is not recognizing anymore...
could it be an SD Card/Scene File thing?
thanks!
-aaron
hey barry,
would you mind checking out my post here, i have the P2 Micon Error and so far my trouble shooting efforts have not been sucessful.
thanks again,
aaron
If it plays, then it's not the card's fault. Have you updated the drivers on your system?
By system, I take it you mean HVX. Driver was not up to date, it is now, and... same thing. Wether importing in FCP, copying in the finder or ingesting in P2 viewer I get this same message : "System error, P2 micon error". I don't know what to do.
Cheers,
Damien
No, I mean on the computer system.
Every piece of equipment that sees that card, needs to be updated. The HVX, the card reader, the computer, the P2 Store, everything. There's a different driver for every stitch of equipment.
Would like to point out that Barry_Green is probably right about this error. I just got it, I have a feeling it's because of my Firewire Bus. None of the clips are corrupt, the P2 Cards are not broken as I can transfer fine (and suprisingly quickly) via USB2.0 to OS X. So, it's a computer hardware issue, not an HVX200 issue.
However, my Firewire port craps out after a few seconds which is strange. I will try it on the G4 Powerbook and Windows soon.
Oh well, guess that's what the PCMCIA slots are for. =P Gotta try one of those suckers in OS X now.
I'm a bit late to this thread, but it did give me a few ideas on what to look into to find a fix.
I started out w/ pretty much the same thing, it seemed to work at first, but then stopped on our lab computers (I work in a school). It wouldn't work on several models of g5s, or mac pros. We figured it was my security, so I tried unmodified systems w/ OSX 10.4.5-11, I tried w/ FCP 5, 5.1, 5.1.4, 6, etc. No luck, but it was still working for one of our instructors on their powerbook, and one of my students MBP.
I tried to transfer via a powerbook... and it worked. I then made it a target disk, and booted a previously 'broken' mac from it, it worked. I tried the other way around, putting a g5 in target disk mode, and booting the powerbook from it, it also worked. So i just pulled my builds out of the equation (a big worry for me). I rebooted the previously broken g5 from its own drive.... and it worked.
To narrow down the fix, I took another 'broken' mac, booted it from a powerbook's drive, it didn't fix it. I took another, and booted the powerbook from it, and it works.
I dont know how yet, but booting a powerbook from a desktop's (put in target mode) seems to fix this problem. I need to test this w/ intel macs yet, and try to narrow down a real fix (is it the firewire controller, is it getting reset when you do this? Is it some setting in open-firmware that is getting fixed? Is it some system-level config that is being reset by introducing the laptops hardware to it?). I also need to test to see if I clone this system if it sticks, or if the individual system needs to have this done (which will suck, I have 150 Macs). I also need to verify this works across my 3 HVX-200s, and 6 p2 cards.
Hope this is of some use to you guys. Ill post more as I figure it out.
Did you ever figure this problem out, bc we are having the same issue with our school's edit bays? I can load off of the camera at my personal workstation, which is the same as the edit systems (G5 connected to Fibrejet), but those systems lock up with the dreaded error message. We logged in as administrator to bypass security, but you can't even drag the raw files to a disk without the error. Students have been off loading files to a hard drive connected to the camera (host mode) and then importing.
I've been having the same issue with my school's P2 cards copying to any G5 computers. I read edixon's advice and tried copying my files to a G4 powerbook and it worked fine. I'm no computer expert but it seems to me that it's an issue with G5 computers.
I'd just like to add that this problem also occurred when I tried copying files via firewire cable to my PC at home. I was able to resolve the problem by using the USB 2.0 option instead.
I haven't tried using the USB cable on a G5 yet.
DON'T try to copy firewire on the PC. And don't try USB on a Mac. Those two options are specifically mentioned in the user manual as being "not guaranteed."
Mac is guaranteed with firewire.
PC is guaranteed with USB.
FWIW... I actually solved this problem on my MAC by changing my camera away from the recommended firewire mode to USB 2.0. I've been using it on USB 2.0 is OSX with no problems; actually, it performs faster (480mbps > 400mbps).
Some research shows that 1394 was developed by Apple, USB developed for Windows. They both work totally fine together; I've used firewire for years in Windows, and USB hard drives for years on Mac. Really does not matter, but I suppose one you could make any argument that 1394 is *more* compatible on Mac... but really... doesn't matter...
Anyhow, switching to USB 2.0 on Mac made my P2 Micon Error disappear.
If you're having a problem, I guess it doesn't hurt to try it. Just remember that they clearly state in the manual that USB mode is not guaranteed to work on the Mac.
We were having this problem in some of our computer labs (Power Mac G5s) too - removing the open firmware password did the trick.
p2 Micon Error fix for Panasonic HPX p2HD
found this thread searching for the p2 micon error with our panasonic HPX p2HD that was occurring on one Mac Pro but not another. This turned out to be the fix!
