Yup. Months have passed. I love my JVC HD110. It's the HDV that I don't like. Form factor. Excellent.. Just what I wanted in a pro-sumer camcorder for years now. Dynamic range, color, adjustments etc. good. Aftermarket battery by IDX, Great. Compression of HDV on tape, sub par. In short on a static image, artificial surfaces (Say a flat wall with flat medium color) the compression codec handles the wall differently frame by frame. Also Reds are pixelated at the edges. This is from the compression, not the camer it's self. If I had a laptop and component inputs and exterior hard drive to capture live it would be great images.
How bad is my opinion? Well in JVC's defence it looks 5 times better than DIRECTV HD DISCOVERY HD Channel. Yet as everyone knows, it's best to keep the best possible signal from the begining and all the way to the end, not start off with a decent image, because by the time you get downrange, it will have fallen apart sooner. I hope some day JVC will give an upgrade to the codec, or even say H264 but at the higher bandwidth at the max the tape can handle as a new firmware upgrade. Who knows, it could happen.
Anyway a friend asked what to get for a series of TV pilots for the OUTDOOR LIFE CHANNEL. I told him the HVX200. When I outgrow this JVC in a couple years I'll probably go up to the HPX-500.
Of course I will experiment more with turning down the detail, keeping the aperature wider to have more of the background out of focus and hence make it eaiser for the codec to keep up and keep things looking better. Any other suggestions out there, or is it just how we live with HDV.
Who knows..... maybe FocusEnhancements will make a portable drive that accepts component inputs and record to it's drive with a less compressed codec. Probably more likely than a firmware update that has H264 at a High bit rate... not the consumer H264 at a lower bitrate...
Otherwise in a year or two I'll get the HPx500 type.
