kurtmo
Eats with 2 Fists
I use Vegas and I usually export cropped out of vegas as a .mov using Sorenson3 at a high data rate (1200K). This go around and I shot in squeeze, I will export my video at 720x405 to get the correct aspect ratio and no bars. Then I take it into QT pro and render out in H.264 to get under the size limit. Works fine for me and I get good quality. Haven't tweaked the final render dimensions yet, but just keep aspect ratio set and should render well.
I've tried to render to H.264 mp4 file right out of Vegas and then just pop into a mov container using QT pro (this avoids a second render). Unfortunately, this gives me some wierd QT error. The only thing I see different between my mp4 files created in vegas and other mp4 files that I've been able to "re-containerize" (QT pro save as versus export) is that the other files seem to use an apple codec, while vegas uses a mainconcept encoder.
Also, as someone mentioned, the audio make a pretty significant difference in final file size.
