Here is the cost of the original post:
HD Case from amazon 37.00
APC battery from Circuit City 59.00
80 gig HD newegg 59.00
so approx. $155.00 US
You might be able to make it cheaper if you use a 60 gig HD
Time with this setup?
It takes approx. 7-8 minutes to transfer a 4 gig card with verify on
Can you use any case/drive/setup?
As long as it is firewire and can be powered via usb. The case I used (macally) came with a usb power connector that fits right onto the battery.
I'm sure you could find other cases/drives/batteries that would work just as well, I was just throwing out a working and easy solution.
I've used it on about 10 location shoots right now and I've not had any problems.
