Dick Campbell said:I also read somewhere that you can use a USB "on the go" drive the same way, because it has a controller built in to it. In which case you would not need a PC, but I don't have one and don't know how to do it.
I'm sure that this probably works...unfortunately I have never been able to make it happen. And I've tried it many many times. I can however make it happen with the OTG firewire drive and 1394 host mode.Barry_Green said:For USB-OTG, just go to the "other functions" menu and put the "PC MODE" setting to "USB DEVICE".
Then switch to PC mode.
Then plug in your USB-OTG drive, and press its button, and it'll automatically copy off the contents of the HVX's cards.
