Xpress 5.6.3 24p clip export trouble
kukyfrope
I'm trying to learn more about how to edit efficiently using Avid and using Xpress Pro 5.6.3 on WinXP and QuickTime 7.1. I've edited a lot of 24pA footage with Premiere/Vegas and know my codecs and all very well, so I'm a bit unsure why this isn't coming out the way I want it to. Why is it so hard to just get a lossless 23.97 AVI?
I shot some footage with a DVX100b in 24pA, so I created an Xpress Pro project in a 23.97 timeline and captured the footage with a PD150. Everything captured easily and it appears Avid removed the pulldown while editing, so I made my edit in the timeline, and wanted to export it. I figured I would export it as lossless and just tweak the colors in AE a bit. But when I go to export it, I can't seem to find the right settings to get the footage out as a true 24p file.
From what I read from searching the forum, it is best to do a QuickTime Reference file and select Digital Mastering to get to After Effects. So I tried that with these settings: http://img485.imageshack.us/img485/6555/avidexport1sj7.jpg
Yet when I open the file in QT to check the render, I can see interlace lines, the playback stutters about once per second, and QT reports the fps as 29.64 (?!)
http://img263.imageshack.us/img263/8260/avidexport2jb6.jpg
My system is not the bottleneck... I have no problem running anything in SD. 2.2ghz Athlon64, 2gb ram, 2x320g RAID0 (media storage), 1x74g Raptor (system drive). Thanks for any help you all can suggest.
I think I figured this out. I didn't try importing the above QT Reference file into AE yet, but when I did, it created a 29.97 comp and played back with interlace lines like QuickTime player did. If I change the comp to 23.97, AE appears to read the original OMFI file correctly and I see no interlace lines.
However, I thought Xpress removed advanced pulldown on capture, so shouldn't those files be in 23.97 on my drive? If so, why would I ever see interlace lines, even if it was played at an incorrect framerate, like QuickTime Player was, and AE was before I changed it to 23.97? Does capturing in Avid remove the advanced pulldown and apply a simple 2:3 of its own or why would this happen?
