Shaw said:This wouldn't have anything to do with OS X now would it?![]()
USLatinContent said:Jason what kind of drives did you put in the enclosure?
Have you checked for average transfer speeds?
I am curious to see how fast the RAID0 controller is.
Jason Ramsey said:...All I know is from real world experience. I put 4-6 streams of 720p/24pn, and have transitions, color correction... all your standard stuff, and have never had anything other than realtime performance in EDIUS...
Finally had some time to reply to this! Not dumb at all. Antec, as I'm certain you're well aware, makes good stuff. Total amperage on the 12v line is actually more important than total number of watts for several reasons. The first is that a PSU might have '600 watts' but have more power than usual distributed to the 5v and 3v lines. Previously PCs relied on the 3v and 5v lines a lot more heavily than today. With the advent of such high powered graphics cards PSU makers have shifted to allocating a lot more to the 12v line. If you don't have enough amperage on the 12v you'll definitely have stability issues. The other issue with PSUs is that there isn't a standard for reporting wattage. Some manufacturers report the wattage at 25 degrees C. Others report it at 40+ degrees C. This is a big issue because as the PSU heats up its efficiency drops. If you have a cheap PSU that was tested as 600 watts at 25 degrees C it will perform FAR under that in real life conditions (where the PSU will certainly be much hotter). This is the reason for the pervasive "get the largest PSU you can buy" syndrom. If you have a quality (meaing tested at a normal case temp) PSU with enough amperage on the 12v rail you'll be perfectly OK.I got an Antec True Power 650W... <Link was that dumb? I got it for only $100 with a sale that was going on ($30 less) but it was more about not knowing how to pick one and wanting to place the order already, so I just picked one hoping it would be good enough... Should I look at the amps on the 12V rail?
Too much power on the 12v rail isn't a bad thing. At least with regard to the issue of destroying components. No worries there. The only time it does become a problem is when you have a PSU that is way over powered for the components you're running and this only because the PSU will be putting out a TON of heat that you will have to expel from the case. Of course, if you don't get rid of the heat THAT can destroy your components. So you won't blow your components by having too much amperage but from having too much heat.It said this: 12V1@19A,+12V2@19A,+12V3@19A,- 12V@0.8A,
And it also said this: "Three 12V output circuits provide added system stabilityAccurate power rating allows TruePower Trio to deliver its full rated power"
So it will only be 19 amps each which won't be "too much" right?
