MattinSTL
Sound Modulator
The pro-dolly parts that are riding Fisher dollies are using teflon sheet as "bearings"... you can buy teflon sheet in any thickness... for example 1/4"... then you can pop that on a drill press... and cut out perfect circles with centered holes and then bolt your wheel assemblies through those two discs... the discs can be permanently mounted on one or both sides... and the only thing that needs to be loose is the friction surface between the two pieces... this is how the lazy suzan effect is being used on EVERYTHING... check the willie's widgets page that was linked... those white discs are teflon sheet.
Buy it on ebay and you can make the thing you want for a dolly wheel assembly that will follow turns.
The point of the bowtie wheels is that you can have a flat axel going through the center just like any skateboard wheel would normally be used... then the bearings are directly, vertically loaded... why do you think Indi-Dolly is doing their dollies like they are instead of just angling the wheels like everybody else? It's because a dolly can be smoother, and hold more weight, with FEWER wheels... if the bearings are loaded vertically... as they are designed to do. The V-groove needs to be deep... like 1.5"... so the wheel needs to be about 4" in diameter (3.5" anyway) and then it needs to be wider then normal to accomodate the flats on both sides... see this way you can follow pipe, or industry standard dolly track... but you can ALSO get down and dirty in a pinch if you have a clean floor... you can roll on clean floor, industry dance floor, pvc pipes, or industry dolly rails... all with the SAME wheel. What's not to like?
The durometer depends on the design... softer wheels yield better results usually... so 78a... but the bearings would have to be recessed in there to shoulder the burden of the load... without the wheel flexing around the center... but if you had an axel... or dual durometer... then that wouldn't even be an issue.
I like the other ideas in this thread also... the follow focus would rock... but matte-box prices have always freaked me out... and rail assemblies too... Rails seem so simple for what they cost.
