Lenilenapi said:Most of us are getting exactly what we expect when we import into FCP - i.e looks the same as when we shot. If your's is looking much darker than i suspect something is off in your set-up in FCP
Barry_Green said:If you want to narrow it down, here's how I'd go about it: generate some color bars in FCP, and export to the camcorder. Then re-import the color bars, and compare against the original generated ones. If FCP is introducing a gamma shift you should easily see it.
Jim2000 said:What settings would you suggest? I'm running FCP 5.0.4
Lenilenapi said:Id on't know how you're NLE's are set up over there, but my first guess is with Ulisses. It sure looks like the difference bewteen 0 & 7.5% black.
BenB said:With 5.1 Apple applied a whole new gamma handling scheme. As for P2 Import window vs. Canvas window, yes, they use different schemes for playback in both. Don't ever trust the P2 Import window to be a true representation.
