Hello,
Yes, it should work just fine, as long as the computer host side is running up the speed it needs to, like you describe. And with Hydra, the long cable lengths should allow for the same situation that commonly exists with film cameras on steadicams, just have somebody behind you taking care of the cable. If you have the entire setup on you or on the camera, that works too.
We should have pricing information within 1-2 months after NAB once we're in Beta. Again, our whole goal is to make this as affordable as possible, we're not interested in having another 'affordable' system that costs as much as a new sports car.
The idea is that if you can afford the host camera, then you probably can afford this system.
Technically, the HVX has a global shutter(CCD). I'm not sure if the SI camera has an external physical shutter but I do know the Altasens sensor is a rolling shutter CMOS sensor, so that may be what you see in the motion characteristics of the DVX/HVX. I think Hydra is aimed at a different price range and market, given the pricing I think somebody looking to use an SI camera is probably also looking at the RED ONE.
Cheers,
Juan@reel-stream.com
So, don't you think that Hydra is an option for handheld/stabillizer work, when done as described?
When will we know the pricing?
Lastly, How will the Hydra compare to the SI-2k? Obviously the PL mount is an advantage, but I love the motion characteristics of Panasonic's 24p
Cheers,
