Joshua Provost
greenlighted said:If this is the case, it might indeed change things. Do you know that this is so, or are you just assuming/hoping?
We'll never know, because Panasonic is not going to reveal how they do it. The end result would indicate that they are doing it properly. We can only reverse engineer and make educated guesses. Seriously, don't sweat it until you get the camera.
Someone wrote here that the squeezing is done by first throwing away the data outside the letterbox and then stretching it to fit the entire "frame". And the amount of vertical CCD lines wouldn't really make a difference because the data there can't be used when stretching the image, right? Or have I misunderstood something here?
True for PAL, but not true for NTSC. Both cams use the same chips. The chip has 576 lines of vertical resolution, regardless of whether it is PAL or NTSC. So, for PAL, yes, you won't get additional vertical resolution, but the color subsampling and DV compression still apply. With NTSC, the 576 vert lines are usually resized to 480 for NTSC to tape. However, in squeeze it would appear that crop-and-zoom is done, not on the 480 line ouput, but on the 576 lines right from the chip, for actual vertical resolutions of around 430 lines, which is what it appears to be.
I've put this theory out on a number of occassions, and so far no one has confirmed, denied, or otherwise commented. I'd like to see some debate on it, actually.
None of that matters to you, since you in PAL-land, but the color subsmapling issue and DV compression still apply.
