Take_1
Avid Media Composer 2.7 RELEASED
New Improvements:
New Improvements:
- DNxHD 36 Avid editing applications now support the DNxHD 36 resolution.
- Compressed Audio Use dynamic relink to link the low-resolution media to the high-resolution source media stored on the media network.
- Lan Browsing 100Base T to ISIS You can now view media with a 100Base-T Connection to Avid Unity ISIS.
- Mac Pro support The Avid Media Composer and Avid Xpress Pro editing applications are now available for the Mac Pro systems.
- 720p/50 Support Avid editing applications now support the 720p/50 format.
- Sony® XDCAM Workflow Improvements. You can now export media to an XDCAM device.
- Panasonic® P2 Workflow Improvements. You can now copy your P2 card to a FireWire® Drive or network drive, import clips and media directory from the P2 card, or write your sequence back to the P2 card.
- Script-Based Editing Updates Script-Based editing is a new feature for the NewsCutter.
- The ability to select all text and takes.
- The ability to double-click any line in a take to select the take and load it into a monitor.
- The ability to specify the text encoding of the script. ScriptSync ScriptSync uses phonetic-indexing technology from Nexidia to analyze the audio portion of a clip and match it to lines of the script text.
- AudioSuite plug-ins The editing applications now include the Time Shift Audio Plug-In.
- Scrolling Timeline You can have the Timeline scroll over the position indicator while you play a sequence.
- Advanced Keyframe Improvements Allows you to adjust your view of advanced keyframe graphs.
- Frame Chase Capture The media becomes available for viewing and editing fro any applications in the workgroup while the capture is still in progress.
- MXF vs. OMF default media. In previous releases, the default media type in the Media Creation settings was set to OMF. The default media type is now set to MXF.
- Adding Text to Multiple Clips Allows you to enter the same comment to several clips at once.
