mrblue1022 said:Shoot on film. I’m not trying to be sarcastic, but filmmakers need to learn the aesthetic of their capture format, and then apply it accordingly. If you want your movie to look like it was shot on film you have to shoot film.
Film at the end of the day is really just a medium. See those stills above? If I said they were from some Asian film production, everyone here would have believe it.wrxguy said:agreed..... If you have ever been to a film set you also notice (as said above) that to acheive the look you want it is just as much lighting and framing of shots, The dvx can produce an amazing picture but it will never be just like film
Thanks for your kind words. I will post better quality stills as soon as possible. I will also post the horror short here as soon as it is done editing (which should be one more week).Craig Ryan said:Nice grabs man! Real quality looking lighting; id like to see some better quality stills just to see them in all their glory.
You can get a great film/movie look out of any stock DVX camera. Use your lights wisely, open up that aperture, and zoom in. That creates the depth of field assoiciated with film/movies; and using light, you can create a 3 dimensional like image by separating your subject/talent from the background, and also improving the percieved dynamic range by enhancing the overall richness of the image. If you want to, add some grain and artifacts in post. All this will significantly make your DVX project look more film/movie originated.
EDIT: and of course shoot in 24p or 24pa!
Vincent Wong Yoon Wei said:Film at the end of the day is really just a medium. See those stills above? If I said they were from some Asian film production, everyone here would have believe it.
It is really the lighting and framing. Film is just a small part of a much bigger picture.
yia said:hi, Joshua Provost...
can you give us rookies some tip on how to get film look....
Joshua Provost said:1. Shoot with the iris as open as possible. There is a catch to this. The iris may be able to open to F1.6 or so (don't know what camera you're using) when at full wide, but only F2.8 when full zoomed. To maintain flexibility, I usually establish the lighting to F2.8 or above, and use ND to bring it right to F2.8. That way I can go full wide to full zoom without changing exposure. You'll need a variety of ND. My DVX has 3 stop and 6 stop built in. I keep a 1 stop and 2 stop around to get in between increments.
2. Zoom in. Example: If you want to shoot a close-up, you can go full wide and put the camera right in front of the person, or you can go full zoom and back the camera up. Either will get you a close-up, but the zoomed one will have a shallower apparant depth of field, becaue the field of view is so small. The background gets blown up so you see it is out of focus. Now, extend this beyond just close-ups. Even medium shots you can probably still back the camera up as far as possible and then zoom in. This is huge. It's probably a more dramatic depth trick than even the iris.
3. Adjust camera sharpening. This is huge. Nearly all cameras do a great deal of sharpening. The camera is fighting against your shallow depth of field. It is taking out of focus objects and sharpening them to make them seem like they are in focus. On my DVX, I have turned the Detail setting all the way down. The image is still sharp exactly where the focus is, but nice and smooth everywhere else. Beyond that, sharpening is just ugly. Check it out, I think you'll be pleased.
4. Light for depth. In B&W, you have to use light to show the depth of the scene and to isolate obejcts. Not so in color, but you can still light for depth with pools of light at different distances, and rim lights to set objects off from the background. This doesn't really effect depth of field, but creates pleasing perceived depth in the scene.
5. Block for depth. Given any shooting environment, position the camera and talent to create distance between them and the background. You can't stick people against walls and expect to get shallow depth of field.
6. Compose for depth. Many people tend to clear out the space between the camera and the talent, but it can help to have foreground objects that will be out of focus. Position the camera to shoot through and around these obejcts. Also, make the background interesting, but not too interesting, so it creates a nice image but doesn't distract.
7. Camera movement. Any type of camera movement (pan, tilt, dolly, jib, crane) will give great feeling of depth because you can see the dimensions of the space change as the camera moves. This is particularly true of dolly in/out and across scenes, and jib up/down. With these movements, the shallow depth of field isn't as important, because you can sense the depth. Shallow depth of field is only a big factor on static shots.
cecil995 said:All this debate is interesting, but I find it rather funny when a good percentage of the general pubic can't tell the difference between film and video....they just know when a picture looks good and when it looks bad.
