Christopher Barry
Juan, are you able to now apprise us of how timecode and/or audio is, or is not, dealt with/recorded in respect of Hydra, and the proposed process when dealing with post production? Thanks.
I agree with that as far as it goes, but are we not then talking about luminance resolution only? The sort of resolution we could see if looking at a black and white test chart? Whereas if a camera such as the HVX looked at a chart lit by pure red or green light, say, the resolution is inevitably limited to that of the red or green sensor only (960x540) - the other two cannot play any part in the imaging process.pertierr said:I'm glad pixel-shift was brought up because it seems like this is an area of some confusion. Imaging sensors are monochrome("grayscale") by nature, so if one looks at just about any single-sensor digital cinematography camera such as, say the Arri D-20, each pixel in the sensor only records one basic color, either Red Green or Blue.
Pixel shift, in simple terms, combines 3 sensors each recording one color(red, green and blue) into an imaging block that functions similar to how a single color sensor of higher resolution works.
In other words, when talking about a pixel-shift 3CCD assembly, the native resolution is the resolution of the entire imager block, not just one sensor. In the case of the DVX this is 1540x984.
Not quite - a resolution chart lit with white light will indicate luminance resolution, but will tell you nothing about effective colour space of the system, the ratio of luminance/chrominance resolutions. But comparing the results when the chart is subsequently lit with coloured light WILL tell you a great deal about system colour space. In practical, non theoretical, use, it will have relevance with effects work - green screen is the obvious example. Your approach would enable you to get true 720 4:4:4 out of a JVC 200, for example, as it has 3x 1280x720 chips - it's the HDV coding that there reduces the output to 4:2:0.pertierr said:The question you post: "what if I have a perfectly red resolution chart?", is one that I've asked myself, but once you -really- think about it, is more of a theoretical excersize than anything else.
I'm assuming a black and white chart, lit first by white light, then (say) red, green and blue in turn. (So red/black, green/black, blue/black lines in turn.) By definition, if the system is a true 4:4:4 one, there should be no difference in the four sets of results. But as you say, 4:2:2 or 4:1:1 coding will indeed make the colour results worse than those for white light.Second, if the lines of the chart are red, then what is the background? Any way you look at it, the sensor will resolve edges anyway.![]()
What it extracts directly from the block of the camera is 960x540 RGB data
I certainly wouldn't suggest that, and having just looked at the Silicon Imaging website I note that whilst they may claim 2k resolution (see http://www.siliconimaging.com/DigitalCinema/News/PR_11_01_06_1.html ) they do not claim 4:4:4. Although their chip may approach 2k luminance resolution, it (like what is being talked about here) cannot claim that for each colour, and hence cannot be accurately described as 4:4:4 - and to the best of my knowledge, they don't attempt to.pertierr said:So would you suggest that all digital manufacturers should change their specs as well? For example, silicon imaging should advertise their camera 960x540 RB and 960x1080 green? It's the same concept. The native frame size of the Altasens sensor is roughly 2k x 1080. I don't hear anybody telling them, or Arri, or Panavision, to change their specs just because their sensors record at most one color per site.
I'm not arguing that at all. Just saying that what you refer to gives no information about colour space, (which is fine in itself), whereas further tests along the lines I suggest will. And to claim a 4:4:4 system, will require the results with coloured light to show the same results as for luminance. In essence, that's what a 4:4:4 system means by definition!We all know what one means when we talk resolution, and the test for resolution is well established using a high-contrast chart with grayscale trumpets. If you are arguing that the common definition of resolution should be changed,.......
