Can I Recapture With Different Preset In Fcp?
wolff75
I shot a music video with my DVX100a, 24PA mode.
Unfortunately, I captured it in FCP 5.1 using the normal DV NTSC preset.
I hadn't noticed my error, and proceeded to cut most of my music video.
Realizing I what I had done, I tried: erase my media, change my project settings to the correct ones, so that my capture settings are now: DV-NTSC 24p (23.98) Adv Pulldown Removal. These are the setting I want, the ones I should have used originally to capture my footage.
I recaptured the footage but FCP seems to ignore the new setting, and captures the footage as before.
I wouldn't mind recapturing my footage from scratch (typing in the IN and OUTs manually), but since I already cut a lot of it, I thought maybe there is a way to simply recapture with different settings, or to "reinterpret" the footage (telling FCP the correct settings), to keep my cuts with the properly captured footage.
Anyone?
Thanks!
Your best bet is probably just to start a brand new project. After that is done change you capture settings and the problem should be fixed.
