720/50p frame rate 50p / 720/25p frame rate 50p ?????
The Flash
Hello,
I have search on forum some explications but it's no clear for me. Can you help me ?
What is difference between 720/50p frame rate 50p and 720/25p frame rate 50p ???
50p 25p
50p 25p
en francais excusez-moi
a 50p il y a 50 images sur une time line 50 donc l'image bouge à vitesse normale
cela est équivalent a une sequ 25 timeline 25 du point de vue de la vitesse ,mais filmé à 50images une sequence avec de grands mouvements ex: sport, aura
une meilleure impression de la qualité du mouvement
50 images à 25p se ''joue'' sur une time line 25 donc ralentie 2x.
For the HVX the story shoud be this one:
- Either you shoot 720p25 or 720p50 the camera record 50 frames/sec, but in 720p25 it doubles every frame. So when you impot it one frame every two is dropped.
- Instead if you use 720pN you can shoot variable speed so if you choose 25 it's really 25 f/sec.
If you look nto the manual you've got a Table that explain it (E33)
Thanks.
So If I want record a slow motion on my FS-100 what mode I need ? 720/50p or 720/25p 50fps ? I think 720/25p 50fps but I am not sure.
That would be correct, yes. But you still won't be able to see the slow-motion effect until you run it through FCP's Frame Rate Converter, or through Raylight's RayMaker.
