Jason Ramsey
Admin
Why wouldn't you want an offloading device, first of all? A cheap laptop, and/or a couple of cheap hdd's will do the trick.
You still need hdd storage space when you go to capture your 15 hours worth of tape. By the time you are done capturing your 15 hours of tape, I will be done with my project and delivering it to my client, and picking up my paycheck.
Not, to mention the fact that I can delete any clip that isn't good on the spot. So that 15 hours of footage might only end up being 5 by the time I get to the editing process. Can you do that wiht tape?
It's just kind of pointless explaining the workflow. If it doesn't work for you. FINE. Geez. it's just so tired listening to you, and others complain about it, and complain about it. You are giving the same tired arguments. Not only that, but the arguments aren't even very accurate, often times, and not based on any actual experience using the workflow.
I walked around for 4 hours in Tornado destruction on Saturday. I had my HVX and 2 8 gig cards. When the sun went down, my cards were full, and I was done for the day. I didn't have the first problem using the HVX and p2 in this situation. 4 hours of walking and shooting.
If you need five hours of footage per day, and can't offload footage, then get the firestore. Oh, wait you already have that. Can you shoot for 5 hours and not offload the firestore, in 1080? Nope. Can you shoot for five hours to 5 tapes. Sure. Then you can go home and spend 6 hours capturing all of that to your HDD's.
I can stick an 8 gig card into a laptop anytime I want, and offload the footage in 4 minutes. Then I am back shooting. Again, why wouldn't you want to have an offload device with you if you were trying to shoot that much footage in a single day?
Give me two 8 gig cards even, and an offload device, and I guarantee you that I could shoot the same thing you would with your tape, have more useable footage and be done and onto the next project long before you. What little time I might spend offloading cards in the field, you will spend 10 times that capturing your footage before you can even look at it, or see if the footage was free from error, etc.
This is tired.
This is tired.
