THoff said:Since the resolution is the same for all SD cameras, the only difference will be in the internal processing and edge enhancement. The HVX generally applies very little edge enhancement, but you can change that through the scene file settings -- those settings work in all recording modes, not just HD.
One big advantage that the HVX has is that it can shoot DVCPro50, which has twice the color sampling information of normal DV cameras. If you shoot that for a SD project, and possibly turn up the detail setting in the scene file, you'll get output that is unmatched by any DV camera.
DavidBeier said:Despite both being recorded in squeezed 720x480, the HVX200 does in fact put out a sharper 16x9 image thanks to it's true 16x9 chip.
No, unfortunately DVCPro50 can only be recorded to P2 media or a DTE recorder / NLE. It's still a SD format though, and if you are producing DVDs, an excellent choice.mushyosh said:oh that sounds good. But can the DVCPRO50 option record to DV tape?
