Barry_Green
Moderator
I would think the ability to "tell" the LCD to flip itself would be maybe firmware updateable. But the DSP function of actually rotating the footage -- that wouldn't be.
It's all a hardware vs. software type of thing. If you're asking for basic core functions of the hardware to be added, that won't happen. Like, asking for an MPEG-4/AVC encoder to add AVC-HD to the existing HVX. That can't happen; an AVC encoder chip is hardware.
But what I'm hoping for from firmware would be things like modifying what's already there to work better -- such as, unlocking additional frame rates that we've already proven are there already; or adding the ability to trim MXF clips so that you can set an in & out point and it trims to just that segment, or telling the LCD to be always rotated. Because the basic functions already exist (we know the frame rates are there, we know the LCD can rotate based on the internal switch, and we know it has a file system for creating/writing MXF files) then I'm assuming (and it's ASSuming!) that those functions can be modified.
Something like a -3dB gain, that's a mystery. I mean, maybe the DSP already supports it, so maybe they could add access to it through firmware. But if the function isn't built in already, then there's nothing firmware could do to make that happen.
In the end, the only ones who actually KNOW what can & can't be done are the engineers at Panasonic. I'm just trying to make educated guesses based on past history as a computer programmer.
