Hello,
I'm shooting an indy feature in the spring and was wondering if I can get some suggestions on a few items as well as some good reliable websites to buy from.
Is this a good microphone? The link isnt working so I am going to post the specs.
Principle of operation:
Pressure gradient
Cartridge type:
19 mm (0.75 in) pre-polarised condenser
Power supply:
48 V Phantom power
Frequency range, ± 2 dB:
40 Hz - 20 kHz
Directional characteristics:
Cardioid
Equivalent noise level A-weighted:
Typ. 19 dB(A) re. 20 µPa (max. 20 dB(A))
Sensitivity, nominal, ±2 dB:
10 mV/Pa; -40 dB re. 1 V/Pa
Equiv. noise level ITU-R BS.468-4:
Typ. 25 dB (correct with the attenuator in 0 dB or -20 dB setting)
Capsule diameter:
19 mm (0.75)
Total harmonic distortion (THD):
<0.5% up to 110 dB SPL peak
<1% up to 116 dB SPL peak
Preamplifier frequency range:
20 Hz to 40 kHz -3 dB (loaded with 2x10 kOhm// 10 nF - equivalent to 100 m cable)
Output impedance:
<200 Ohm
Cable drive capability:
Up to 100 m (328 ft)
Microphone length:
175 mm (6.89 in)
Max. SPL, peak before clipping:
158 dB
Weight:
165 g (5.82 oz)
Dynamic Range:
Typ. 97 dB
Switchable attenuator:
0 dB, -20 dB
S/N ratio, re. 1 kHz at 1 Pa (94 dB SPL):
75 dB(A)
Connector:
3-pin XLR-M (Standard P48)
Current consumption:
2.60 mA
Thanks alot.
JP
Pressure gradient
Cartridge type:
Power supply:
48 V Phantom power
40 Hz - 20 kHz
Cardioid
Capsule diameter:
19 mm (0.75)
Output impedance:
<200 Ohm
Microphone length:
175 mm (6.89 in)
158 dB
Weight:
165 g (5.82 oz)
Dynamic Range:
Typ. 97 dB
0 dB, -20 dB
75 dB(A)
Connector:
2.60 mA
Thanks alot.
JP
