Ok well I might be getting a mint dvx100a from someone I know and it has 260 hours on it. Should I get a professional head cleaning on the camera or should it be fine?
If you know the guy that you're getting it from... has it had normal or routine maintenence...??? I'm sure it's been cared for... I mean it hasn't been dropped... or dunked in the ocean...???
Chances are that it is good working condition... it should last for quite a few more hours... but...
If it's in your budget... you really should let an authorized service center have a look at it. Maybe not so much the heads... but cleaning the tape path, rollers, guides and such... just making sure that it's within specs... certainly would assure good performance in the long run...
I would... then again I'm just a retired old hippie with everything in working order... (knock on wood)...
