Sad Max said:Just picked up a four-month old Letus 35FE with a Canon 50mm lens for $520.
Someone tell me I did right...
i think you'll be ok. You shooting a1? i saw disjecta using it on the xlh1. looked good to me. VERY organic and pretty.
www.adapterplace.comis there a web site that i can look at to see the letus adapter
TimurCivan said:That shouldnt matter because the GG is going to trnadsmit light at a constant rate. Overexposing the CCD is what you have to worry about. I have tested 5 different 35adapter, and all ofthem behave EXACTLY the same way except the go35.
The more light you get to the gg the better. However if you felt that yo uwanted deeper DOF outdoors, closing the Iris on the 35 lens down to F16, and opening your DVX/HVX/a1 lens to open produces the same results, as leaving the 35iris open, and closing down the DVX iris, with regard to exposure and picture quality. This is the firs time in history that you can practically choose your DOF, then adjust expsure, without a massive lighting package and stacks of NDfilters.
The go35 and G35, static adapters NEED the GG to be fully and prperly exposed at Wide open on the lenses, otherwise static Grain shows up
TimurCivan said:i think you'll be ok. You shooting a1? i saw disjecta using it on the xlh1. looked good to me. VERY organic and pretty.
THX-1138 said:It's like a hazy filth that apears to be laying on top of the footage.
eureka said:Hi Guys
Looking at all the setups using the letus35FE, is it just me, or do all the setups look cheap and nasty, has anyone gota pic of a pro setup. cause Im saving up to buy one but if it looks shonkey, forget it, I'II look for an alternative, btw is there a alternative at the same price which at least looks pro?
TimurCivan said:Or an SGpro... or an M2.... OR a Go35......
Theres Tons of options now.
