liextreme said:The problem is that I have to shoot in a small office, and how can I do wide and sill have the depth on the object? any lenses?
Mark A. Beal said:Something I've never done but always wanted to try is hanging some sort of frosted/transluscent material (like a shower curtain, maybe?) behind the subject to blur it. I actually recall finding a link to a product for that specific purpose a few years ago, but I can't find it or remember what it was called. Does anyone here know what I'm talking about?
liextreme said:ok m2 $550 I think that is the answer, now what lens and where do I get it?
Ted Spencer said:Not to be too picky with the language, but as dougspice pointed out, you appear to be asking about how to *decrease* depth of field, not increase it. The term "depth of field" isn't synonymous with "shallow depth of field". It describes a range of choices between shallow and deep, also sometimes described as short and long. Here's a brief summary of what affects it:
First and foremost, the aperture size, or F-stop of the lens is the primary means of control over DOF. Larger aperture sizes (with lower F-stop numbers) have inherently shallower depth of field, and smaller ones (with higher F-stop numbers) have longer DOF. So if you want a "shallow" effect, use a low F-stop setting, like 1.4 on the HVX, which is the lowest available. It also affects light input, so a low F-stop will require much less light on the subject than a high one. So a low F-stop number = shallow depth of field and higher light sensitivity, a high F-stop = long depth of field and lower light sensitivity. You can counteract excess light at low F-stops by using a faster shutter speed, reducing light (when possible) or using an ND filter. For higher F-stop situations where you want long depth of field and need more light, well...add more light.
The HVX like many camcorders is inherently limited in its available range of DOF on the shallow side. It has mainly to do with the small sizee of the CCD light sensors. Even with the aperture wide open it's not going to give you the kind of super-shallow focus effect you might be looking for. This is why there are a number of aftermarket products like the Redrock M2 35mm adapter. The main reason such products exist is to allow shallower depth of field than the stock lens, although they also allow the use of many other types of lenses to enhance zoom, wide angle etc.
As some have mentioned, there is one other way to get the shallow DOF effect with an HVX's stock lens, and that is with zoom. Put the subject as far as possible from the background you want soft focus on. Zoom in (magnified) all the way on the subject, move the camera as close to the subject as proper framing will allow, and use as low an F-stop as possible. It will give you a nice shallow DOF effect. Among other downsides though, it will distort the perspective of the background due to the zooming. Background objects will be blurry, but will look disproportionately large/close due to the magnification effect of the zoom. This is nonetheless the best that can be done to achieve the effect with the stock lens.
For myself, having completeted assembling a very nice HVX "starter kit" this year (camera, tripod, lights, field monitor, shotgun mic, lavs, FCP, P2 cards, powerbook...etc, etc, etc...whew!), one of the first things I'll likely add next year will be a 35mm adapter kit and lenses.
