Hi,
I have just purchased a Marshall 7'' HD monitor and V-mount Battery for my HVX. The problem is the monitor with the battery seems too heavy for the Noga arm to handle. The resulting configuration ends up either swiveling or flopping backward.
Just looking for any advice as to how I should position the monitor and arm?
Right now I have the noga arm attached to the hotshoe and folded in on itself with the monitor mounted upside down, for use with a redrock M2 adapter, and the battery attached. This configuration seems o.k. but I when I try and lean the monitor slightly back the whole thing just flops over due to the weight.
If I could tighten the Noga arm Joints I think that it would fix the problem but I can't figure out if that is possible. Any thoughts?
Should I just give up and remove the battery to another part of the camera and run a wire to the monitor? Do I need a better arm?
Any advice would be great.
