Firestore to HVX to monitor - Wha Happen?
You can play footage from the FS-100 to any NLE live. You'll use the FS-100's DV Firewire port, NOT the "Computer" Firewire port. Then hit play on the FS, it'll feed a regular digital video stream just like capturing live from your HVX.
Beautifull!
This is a great way to view previously recorded files in the field in full resolution.
I mostly use DVRack HD as a monitor anyway. Next question is can you stream to both Firestore and DVRack simultaneously?
To firstore for recording and still be able to periodically plug in dvrack for monitoring. I want to keep all the data consolidated on the firestore but be able to split the signal for occasional monitoring with scopes on laptop. Since there is no loop, maybe a firewire repeater? In fact perhaps this could be used as backup rec on laptop at the same time
