Daniel Schaumberger
Hi David,
normally you can mount the VH-72ND directly to your achromat/camcorder but if you get vignetting or you cant focus on gg (depends on camcorder used) you will need some empty 72mm UV-Filter rings to get some distance. From others I know that with a +10 achromat the distance between camcorder and gg should be about 40mm to get rid of the vignetting and focusing problem.
If you cant find a 72mm tube with 40mm in length buy the cheapest 72mm close up filter set from ebay and take out the lenses that should be the right length.
best regards
Daniel
best regards
Daniel
