Hi All,
Just finished a 3 day shoot on a project and got the chance to shake out my BoomRecorder (henceforth refered to as BR ) setup so I thought I would share my experiences.
Here's the setup:
Most of the film was interiors (at a mortuary, no less, and somewhere there is a picture of me and my cart in the casket room...I'm hoping to get a copy of it for my Web site). Scenes were pretty straight forward, with no more than 4 actors in any given scene. We were shooting on the HVX200, with a solid DP and grip/gaffer. I was working with a novice boom op, though.
Here's my setup:
-BR running on a new MacBook
-Alesis MultiMix Firewire 16 channels
-Tascam HD-P2
-3 Sennheiser G2's with CountryMan B6's
-1 Shure wireless (don't even remember the model - desperation mode) with a B3
-ListenTech monitoring
-Interiors: Rode NT5
-Exteriors: 4073a (again, remember, novice boom op)
-Denecke TS2-SB slate
So, I setup up my usual mix, sending boom left and everything else R. Took the main outs to the Tascam, and went FW into BR. I generated 6 channels of audio in BR, resulting in 6 files per take. For mounting the lav's, I used the Rycote stickies for the first time and really like them (coupled with the Dr. Scholls corn pads, little or no clothing noise). I set the Tascam up as if BR wasn't there so I still had what would have been my standard mix. The slate was the master for TC, jammed into the Tascam and BR. I also sent control room L to the camera for triple redundancy and dailies.
Overall, things went well. I turned in over 22 GB of sound (both from BR and the Tascam.)
Here's some of my insights:
- I had a few panic moments at the begining of the shoot when the file sizes on the BR files weren't matching up. Turns out it's a refresh problem in Finder - if you close finder and come back, every track recorded is the same size.
- If you aren't using a cart, you must get one. My current cart came from Home Depot and cost me $39.95. It's one of those wire racks with the adjustable shelves. It made moving between setups a breeze. (As usual, I forgot to take any pictures, but a couple were taken and have been promised to me).
- Be an absolute stickler for getting cell phones turned off (not just on silent). With the wireless, everything ran great (no hits or dropouts) until this morning, when one helpless person thought that all cell phones off didn't apply to her (of course I made sure she was thoroughly embarrassed - she was just the videographer for the behind the scenes).
- BR is amazing. Once I figured it out, it was incredible. Easy to use, lightweight, I can't say enough. And, it's really cool that with the new MacBooks you can start it and stop it with the remote control (conveniently velcroed to the front of my cart so all I had to do was push the remote and the record on the Tascam and go).
- One downside to BR that I have found (I need to research more on this) is that because the notes write when you stop recording, there were a few takes where I recorded lots of extra because I was a bit behind in my notes. I think this is just a workflow issue for me that I need to work on.
- When you have a DP that yells at the boom op for getting the boom in the shot, be sure to praise him/her in front of the rest of the crew, gently. It really helped my boom op a lot when I told him that if he wasn't dropping into the shot occasionally, that he wasn't doing his job right. The DP had scared him to the point where he was aiming about 6 feet above the frameline.
- I need more 50' cables. Now that I have my cart, I'm sitting further away from the action and 4-50 footers would have been a big help. Matt - price quote? ;-)
- It is really nice to have an extra set of hands on set. On Friday, I had to leave the set for a couple of hours, so I brought in a substitute (Scott Koue/Noiz-thank you for the recommendation. Ian was GREAT!) This is the first time I had someone on set that knew anything about sound besides me, and he showed me some great little things, especially in setting up my cart, that I am going to use going forward.
- My sound blankets still have not arrived, but fortunately I didn't need them for this shoot. The one echoy room (the room where the bodies are prepared) was shot MOS, fortunately.
- Am I the only one that wishes that actors would use the mute button on their Tx's before they go to the bathroom. Nothing worse than putting my headphones back on and hearing grunting and splashes.
-I used my Portabrace hard cases for the first time on this shoot, and they are every bit as good as the Pelican's (and I do like the blue color better than the grey).
- Not sure if this is a California thing or a national thing, but battery disposal rules changed here and now they have to be treated as hazardous waste. I made sure my agreement included a clause that the producer was responsible for proper disposal (we went through more than 100 AA batteries).
- One incident early on with BR caused another scare. The TC would not stay in sync. This started right after a circuit blew and I lost power to the mixer. Quitting BR and restarting it solved the problem, but I scrambled for a bit before deciding to try that.
- Do not forget to take your headphones off before jamming through the mixer. Ouch.
- The Denecke slate does not like phantom power. ;-)
- Burning data DVD's on the Mac is painful. I think in the future I am going to recommend that the director bring a hard drive and I will dump all the files direct to the hard drive. It took me an extra 30 minutes or so to burn the final DVD today (the Mac burn data DVD software is painfully slow... the verification of the burn takes longer than the burn itself. Maybe someone can suggest better software or a setting I missed).
- The pre-fader/post-fader issue Jeff Wexler reported with the Alesis was not a problem on this shoot. The board worked great for me.
- The lead actor (the director's father) among other things is a very famous plate spinner/juggler from India (he was also in "The Terminal" with Tom Hanks). Let me tell you, those plates are loud and unpredictable. Lots of blow outs. I finally just throttled back one channel heavily, and it came out okay. (And, I do have to admit, I did leave the board on one take so I could watch his routine...and he is amazing even at the age of 88).
- Something I did not know: The HVX can send NTSC signal to a monitor - it does not require an HD monitor. I did not bring my monitor because of this, and wish I had. I always feel like I'm much more effective when I can see what's going on.
- A dog drinking soup out of a bowl ranks right up there with listening to two people kissing as one of the more disgusting aspects of being a sound mixer. ;-)
That's about all I can think of right now...I'm tired. I'll add to this thread later if I think of anything.
Phil
Here's the setup:
Here's my setup:
-Tascam HD-P2
Phil
