Jeremy Ordan
Major Contributor
For 11 weeks now I have been checking out the images posted for our weekly contests and the one criticism I offer more often than anything else is: look into Rule of Thirds.
Essentially the rule of thirds says that your action or focal point should fall on a division of the frame. This is sort of counter to what most people try to do with what I call the 'Vacation Photo'; where your subject is in the dead center of the image. By using the rule of thirds you add drama, tension, and an overall more pleasing effect to your image and it is as simple as composition.
Here is a better definition I stole from wikipedia:
By applying these concepts to your personal projects you will not only see better, more professional images, but also be able to control your audiences eye and direct them where you want in your image.
The rule of thirds is a compositional rule of thumb in photography.
The rule states that an image can be divided into nine equal parts by two equally-spaced horizontal lines and two equally-spaced vertical lines. The four points formed by the intersections of these lines can be used to align features in the photograph. Proponents of this technique claim that aligning a photograph with these points creates more tension, energy and interest in the photo than simply centering the feature would.
The photograph to the right demonstrates the application of the rule of thirds. The horizon sits at the horizontal line dividing the lower third of the photo from the upper two-thirds. The tree sits at the intersection of two lines, sometimes called a power point. Points of interest in the photo don't have to actually touch one of these lines to take advantage of the rule of thirds. For example, the brightest part of the sky near the horizon where the sun recently set does not fall directly on one of the lines, but does fall near the intersection of two of the lines, close enough to take advantage of the rule.
The application of the rule of thirds to photographs is considered by many to make them more aesthetically pleasing and professional-looking. The rule of thirds can be applied by lining up subjects with the guiding lines, placing the horizon on the top or bottom line instead of the center, or allowing linear features in the photograph to flow from section to section. In addition, many photographers recommend treating any "rule" of composition as more of a guideline, since pleasing photographs can often be made while ignoring one or more such rules.
