HVX, FS-100, 2 projects... need to separate - any ideas?
hello-
due to extenuating circumstances, i was forced to shoot 2 different projects on my FS-100 without being able to download between. so i have an SD project for one client and an HD project for another client all on one FS-100. i need to deliver in P2 format to both clients without the other clients project included. :huh:
as if that's not confusing enough, it appears there's no easy way to separate the files in FS-100, hence this post -- any ideas?
thank you!:dankk2:
e3
Can you copy to a Virtual P2 card using shot marks and P2 viewer. Files should be easy to distinguish from each other. - SD or HD
Mixing formats before off-loading and formating is not the best idea. You're probably safe, but it's very frowned upon by Focus.
When you run P2 Organize, all the clips will be together, you'll have to sort them all out manually.
