I bought this 35mm kit a few months ago. The adapter works very good on my FX1 ( I got it aligned perfect for the FX1/Z1U). I'm selling because i'm using a Canon XL-H1 now on my projects with a mini35 from my school.
Here is what the kit contains:
1) One 35mm spinning adapter made after the Micro35. It features:
- Adjustable Canon FD lens mount
- DCX (condenser lens)
- Quality macro assembly (achromat) with 72mm ring
- Potentiometer to control motor speed and reduce power consumption
- Materials: ABS tubing and aluminum
- Works on two AA batteries inside the unit
2) Rod support system
- Aluminum/stainless steel
- 13” long stainless steel rods (tubes, actually)
- Two 1/8” aluminum shims
- 1/4-20 hole and thumbscrew for tripod mounting
3) Five optical acrylic, laser-cut GG discs + Redrock M1 GG
- Three sandblasted discs with different degrees of diffusion
- Two “virgin” discs for you to sand or grind to your taste
- Disc Thickness: 1mm and 1.5mm
I am also including a 35mm Canon FL F/1: 2.5 lens
All you need to start using the adapter is an adapter ring to 72mm and, maybe, extra shims to bring your camcorder to the desired height.
http://www.geocities.com/nomrulz_1999/DIYADAPTER.jpg
http://www.geocities.com/nomrulz_1999/RedrockMicroDIY.jpg
I'll try and upload some footage asap
I'm asking $350.00 plus shipping for everything. Shipping to USA only, but maybe worldwide if necessary.
