DC
Cinematographiliac
Using Avid Xpress Prop HD v5.5.3 with a 720p 23.976fps project. . .
Ok, a bit of confusion here. I've never run into this problem with my own Avid projects and my knowledge is a little gray in this area. I'm hoping someone could explain this thoroughly.
My friend, who I'm working on a project with, is trying to export a Quicktime movie from an Avid timeline. He was originally exporting it as 601 and the color (upon playback) was looking very washed out. I advised him to try exporting as RGB and when he did, the colors looked great.
I realize that 601 color is for broadcast and RGB is for a computer monitor. I guess what I'm trying to get at is should this Avid project be set to 601 and then exported as 601? I suppose the monitor would also have to be calibrated as 601 color with say, a Spider? Also, how does the Avid codec selector factor into this - should it be used?
What is the step-by-step configuration for setting up, working in, and exporting 601 color that will look proper on a computer monitor and television?
Just looking for the best all-around solution. I would appreciate any help with this.
