Barry_Green
Moderator
UPDATE: The Glitch may be related to putting P2 Cards in without using the write-protect tab. If you always always always always always write-protect your cards, and still get "the glitch", then please write in and let us know. If you get the glitch, and you don't write-protect your cards, let us know. If you use the P2 Store to import your cards and you never get the glitch, we don't need to hear from you -- the P2 Store acts as an automatic "write protect" device. If you use the P2 Store to import cards and you DO get the glitch, please let us know.
I'm asking for the community's help. If you use an HVX and you use a Mac, please read this thread and help us solve this problem once and for all.
I don't know about you, but I've had about enough of reading from people about "why is my footage trashed" or "why doesn't my P2 volume mount" or "why is my clip corrupted" or "why won't my clip import"... let's get some concrete solutions for these people.
And the first step is to identify the problem. Identify exactly what situation it is that causes these glitches, and then hold the responsible party's feet to the fire until they FIX IT.
For those who don't know what I'm talking about: there is an issues where occasionally when someone imports a clip on a Mac, they get a glitched frame or two. It looks like a DV tape dropout. This is an extreme example:
Other examples show just one or two little blocks of corruption. But as far as I'm concerned, *any* corruption is completely unacceptable.
And this is not an isolated case. I took a quick scan through just the first part of our Technical forum and came up with several threads griping about the same issue:
http://www.dvxuser.com/V6/showthread.php?t=60516
http://www.dvxuser.com/V6/showthread.php?t=73623
http://www.dvxuser.com/V6/showthread.php?t=62737
http://www.dvxuser.com/V6/showthread.php?t=69091
http://www.dvxuser.com/V6/showthread.php?t=65405
http://www.dvxuser.com/V6/showthread.php?t=61374
LET'S GET TO THE BOTTOM OF THIS.
I'd like to hear from those of you who've had this problem, as to what it was that you did when the problem occurred.
IF YOU'VE NEVER HAD THIS PROBLEM, PLEASE DON'T RESPOND HERE.
Posts that say "never happened to me" don't help us at all. We have thousands of HVX users here, and have the ability to test the system in far more ways than Apple could, so let's help them by figuring out the exact circumstances and then telling them. And then it'll get fixed.
From my research, we can rule out FCP entirely. I believe FCP is innocent. I believe instead that it's related to either the particular chain of hardware used, or perhaps conflicts from some terminate-and-stay-resident software.
So for those of you who've had it happen: what was your workflow? Specifically:
1) Did you try to import footage directly from the card slot of a Powerbook G4 straight into FCP?
2) Did you try to copy footage directly from the card slot of a Powerbook G4 onto a hard disk, and then import from there?
3) Did you try to copy footage (or import footage, either way) using the camera as a card reader, hooked up via 1394 Device mode?
4) Did you try to copy footage (or import footage, either way) using the camera as a card reader, hooked up via USB Device mode?
5) Did you try to copy footage (or import footage, either way) using the external five-slot card reader?
And, do you use any external firewire hubs to connect hard disks, or daisy-chain the camera through a hub (or through an external hard disk) or anything like that?
An interesting post from Kevin Railsback points me towards my conclusion that it is almost unquestionably a problem with the PCMCIA driver:
http://www.dvxuser.com/V6/showpost.php?p=653842&postcount=9
In this case there is no firewire involved, no firewire hub, no daisy-chaining, no FCP, no "disk image", no anything. Not even a transfer to disk! Just a card stuck in a Powerbook slot. And the glitched frames happened (and later corrected themselves). But I reserve indicting the driver until we find out whether Kevin was running some TSR programs or something that could have complicated the matter.
Let me take a moment to say that there are thousands of very happy, productive, satisfied HVX/Mac owners. The overwhelmingly vast majority of users do not appear to have this problem! We know that, and are happy for them. But some are being affected by this issue and I believe it's time that it gets fixed. Or, if it's user error in any way (such as connecting your drives through a hub) let's definitively find that out, so we can give them proper advice to eliminate the issue from ever affecting them again. Any valid scientific "debugging" advice that you, the masses, can provide will be forwarded to the appropriate people to assist them in finding and fixing any potential issues.
Here's an example of what I'm talking about: if you've had the issue before, let's try to re-create it. If it happens when directly copying on your G4, then could you take an hour (maybe while watching "Deal or No Deal")
and just repetitively copy a card over to an external hard disk about 20 times or so. Then use a binary file compare utility to compare all the files against the files on the card, to check for any corruption whatsoever. Doing something like this would be very helpful for finding if any corruption has occurred, and would probably be far more reliable a way of testing than it would be to just look at footage for glitches.
Thanks all!
Thanks all!
