Bogen 503 pan tension???
bart
I own a bogen 501 head and when I crank up the PAN tension it just dosen't get stiffer than what I would like it to. Anyone know if the 503 gets Stiffer than the 501?
Bart
i have the 503 also and the lil lock that tightens the pan goes left and rite and when i try to tighten mine there is always a slite pan to it dont know why it would lock it down completly when turned all the way to the rite.
bilgami, the tension on the 501 is a round knob that is located directly under the plate holder and has a + and - on it. It sounds as if your talking about the pan lock instead. But, then again you have the 503.
The tension knob is used to balance your tripod head, not to lock it. If it's head heavy you go "+" until it is balance.
